Security
Redcare Secure IP
Redcare Secure IP uses an IP network or broadband line as the primary signal, with backup provided by a mobile network connection. If the primary signal fails, then our intelligent roaming mobile connection kicks in. In other words, this dual path system provides secure, grade 4 alarm signalling where it’s needed most.
Redcare Secure IP is LPS 1277 third-party certified, which exceeds European and British standards and is preferred and specified by insurers, making it the best choice available.
With a remote manager web portal, giving you access to remote diagnostics and servicing information, Redcare Secure IP puts you in control.
Redcare Secure IP
The perfect combination of online and mobile signalling
Key benefits and features:
LPCB C Logo
  • Our intelligent Roaming SIM comes as standard and automatically switches between the main UK mobile networks for the best signal.
  • Redcare Secure IP can be installed anytime with our easy network connection.
  • With a remote manager web portal, you’ll have quick and easy access to remote diagnostics and servicing.
  • We've been leading the way in reliable alarm signalling for over 30 years so you know you're in safe hands.
Downloads
