Security
Redcare Secure 2
Redcare Secure 2 provides the perfect solution for lower risk sites. This dual path, grade 2 system uses mobile technology for its primary signal, with a secondary phone line signal whenever it's needed.
Powered by our intelligent Roaming SIM, the mobile signal automatically switches between the main UK mobile networks for the best connection.
The Secure 2 system can be upgraded to Secure 3 or Secure IP at any time, so you'll always have the right protection in place, whenever you need it.
Redcare Secure 2
Reliable alarm signalling where and when you need it
Key benefits and features:
LPCB C Logo
  • There are no additional setup costs and no extra call charges.
  • The Secure 2 system can be upgraded to Secure 3 or Secure IP at any time, so you'll always have the right protection in place, whenever you need it.
  • Our intelligent Roaming SIM comes as standard and automatically chooses the best signal from the main UK mobile networks.
  • Redcare Secure 2 can be installed anytime with our easy network connection.
  • With a remote manager web portal, you'll have quick and easy access to remote diagnostics and servicing.
  • Redcare Secure 2 can be upgraded to the Secure 3 or Secure IP system easily, without the need for any hardware changes.
Downloads
